-   -   thx closed (https://www.racingjunk.com/forums/showthread.php?t=17446)
triplexdogg08 05-31-2007 09:49 AM
thx closed
close the thread thx
altune 05-31-2007 02:30 PM
you need to find out what crank is in it , rods etc.
usually those engines , fresh with oil pump and pan making 750 hp would go for about $5500-$6000 with base internals, Eagle stuff etc.
and the heads are really not that much $$
bjuice 05-31-2007 02:57 PM
what altune said i agree with..
i want to add to this you can get a 540/565/582 all standard deck short blocks brand new and assembled for about 5600........depending on the type heads you settle on ( coventional) you can buy a complete set for right at 3500..or so......
do not get coned into paying someone worth more than what a set up is worth just because they got took by someone else.
thanks- Brian
