plug reading
hi guys
need to know what you think......I have a ZZ4 350/355 i check the plugs today.....the porcelain is off white the ground strap at the top is a lite green color no oil on plugs. do you think i need to back off the timeing a little.... timeing inital 12 total 34 ZZ4 350/355 intake power plus open plain demon 750 edelbrock rpm heads 202/160 64cc crane hydraulic roller 234/242 adv duration 296/304 lift 539/55 1.5 roller tips msd distrbutor no vacuum advance.................thanks....Butch |
Any pictures of the spark plugs?? Hard to say from here
Butch my friend...good to see you post.
Like Tom said, post a pic of your plug....these guys will tell you exactly what you need to do, and what is going on with your plugs. |
plug reading
http://img175.imagevenue.com/loc479/..._122_479lo.jpg this is something like my plug the porcelain
and ground are like mine ......mine are not BLACK like this one |
Doesn't look to aweful bad,but I got a question? Why are you running a power tip spark plug?
Is this a strickly strip engine? Or do you run this on the street too? |
street car autolite 104 plugs
I think the plugs look fine for what you are doing with it, I wouldn't touch a thing 8)
ok tom......thanks.......Butch
| All times are GMT -8. The time now is 07:37 AM. |
