-   -   2 bolt block?? (https://www.racingjunk.com/forums/showthread.php?t=17456)
dunn383 05-31-2007 06:35 PM
2 bolt block??
I have a 2 bolt one piece rear main seal block and am wondering how much power can it hold if I fill the block and tap the mains for 4 bolt caps? Also, how far is too far to bore the block even with it filled?
chevguy65 05-31-2007 08:17 PM
What size block???
Small or big block?
Some information will be helpful
dunn383 06-01-2007 06:44 AM
Sorry, its a 350 from a 1990 chevy truck. I plan to use it for racing only if I can.
edvancedengines 06-01-2007 07:21 AM
Check to see if that block has a place on each side for a dipstick. If it does, I wouldn't put more than a max of 550 to 600 hp to it if using a stoke stroke crank. If you want to stroke it to a 3.75 that would still be ok.
If it has only one dipstick hole it is more likely to be a USA made block and with all the previous included but with using a main cap girdle or 4-bolt or splayed caps and a block half fill with Hard Blok and fully prepped the block should be able to take 850 hp.
The SB Chevy block is one of the strongest factory SB engines there is, IF it is not made in Mexico or is a Target Block, also made in Mexico.
Warning:
I do not like aftermarket cast steel crankshafts. Factory cast iron is as good if not better. Factory nodular iron 400 SB Chevy cranks are killer and will handle anything your block can.
Ed
hink 06-02-2007 07:07 PM
Warning:
Ed
We only rate our best blocks at 600 horse with spayed center caps, front billet cap and a strap on the rear main cap and sonic tested for cylinder wall thickness.
Hell Dart only rates there Sportsman block at 900 horse and thats 10 times the block any of the 010 type blocks are and your saying its good for 850 horse.
I really need the P/N of the block your using as I guess I have been missing some thing here HMMMMMMMMM
