Stud Girdles , water pump.
Do you think stud girdles are really worth it? Its a daily driven car with a mild 302. I already have guide plates. And is there any increase in power or just stablizes it more?
Also i know you see soem horsepower if you change to a electric drive on your water pump but do you have to have an electric fan or can you still us the mechanical one? So how much horsepower do they even free? Thanks |
I think needing a stud girdle would depend on how stiff your valve springs are and how much lift your cam has. If its a daily driver then you probably don't need a stud girdle unless it has a huge cam and wicked springs which would make it somewhat unreliable in my opinion. I think you would gain more from having an electric fan than an electric water pump, plus it would be hard for an electric water pump to keep up with the demand of a long distance driven vehicle. The electric fan will help save your water pump, especially during those higher rpm episodes that seem to happen with hot rods. I had an electric fan on a daily driver and had it wired to a toggle switch so I could turn it off on the highway. As long as I was driving over 35mph it was fine with the fan off and that was with a somewhat built 429. Chris
Ya i thoguht so but I have and mechanical water pump and was gonig to put a waterpump drive on it. I was just curiosu if you need to switch to an electrical fan and how much power it would make if you dont have to switch Thansk for the info on the fans thoguh
| All times are GMT -8. The time now is 09:29 PM. |
