-   -   rear drums (https://www.racingjunk.com/forums/showthread.php?t=17498)
spib 06-05-2007 05:19 PM
rear drums
has anyone had an experiance with a warped drum? or drums? when the car is jacked up and you turn the tires there is a spot were it slows down and is harder to turn, you turn threw it and it gets easier again untill a certain spot again. When I had the brake drums turned , he said they are warped some, but should be ok. with the drums off it all turns fine, will this be ok , or should I replace the drums?
jbsjunk 06-05-2007 05:33 PM
New drums are pretty cheap for those. Bet you get out the door for under $40.
spib 06-05-2007 05:55 PM
for a 11" drum 2.75 try $115 each drum mopar 8.75
etbird 06-05-2007 06:29 PM
Damn Mopar stuff. It will self clearence. Maybe. Mine has been like that for 30 years.
jbsjunk 06-05-2007 06:40 PM
Oops! Didn't know you were running a Mopar diff. :oops:
lively 06-05-2007 07:10 PM
JUST TAKE IT AND HAVE THEM TURNED AND IT SHOULD BE FINE----IF IT IS THE BRAKE PADS THEY SHOULD WEAR IN :) :)
spib 06-05-2007 08:32 PM
yes I am running a mopar diff, my mopar friends are comming over wensday night to look at, they said it will wear down and be ok, will see, hopefully that is the case!!!!
spib 06-06-2007 03:15 AM
the drums have been turned, and all the brakes are brand new, the guy who turned the drums is the one who is going to come over to look at
