Ground Wire Size
I am looking to mount a ground block for all my ground wires that has a line that runs to the battery. What I need to know is what size whould the wire be that goes to the battery from the trunk. Also what size wire should I use for ground wires.
Thanks |
I personally use a #10 wire from the battery in the trunk to a ground block up in the front of the car.I use this for a few direct grounds,for the nitrous system,only to keep other grounds such as ignition,water pump and fuel pump,which are grounded to the chassis
Robinhorn,
Here is some useful info from Shogun. https://www.shogunindustries.com/cgi...ch/ground.html Curtis |
| All times are GMT -8. The time now is 05:54 AM. |
