valve covers w/holes
im going to run a vacum and was wondering if it's ok to get valve
covers w/holes or should they be no holes for sealed vacum? thanx for any help :) |
No Holes
You want to seal the engine as best as you can. No holes or air leaks if possible. A well sealed engine with a vacuum pump will give you a little more power.
| All times are GMT -8. The time now is 11:54 PM. |
