8896 baseline ???
motor 565 afr 345 heads ,9.8 to 1 ,cam 739 lift 270 at 50 dur , 2-1/8 headers ,8896 1050 dominator ...runs rich at idle and top end ...(black smoke out exhaust)
is there idle feed restrictors i can reduce to get cleaner idle in this carb? i know just needs some jetting work just trying to get a starting point.. do you guys run power valves? thanks in advance |
sorry forgot to mention car sees a lot of street time ...
Start with 86 jets in both sides and 4.5 power valves with the mixture screws 1-1/4 rounds out from softly seated.
Mark |
i had same problem and pro systems fixed it and also gave me more horsepower. I have a 572 bbc 9,7-1 in recreational boat. Idled too rich and just didnt run right. They didi all kinds of stuff and it really made a big difference. Cost me $430, but was worth it.
put 86 jets in all i had was 5.5 power valves ,put those in adjusted screws they are 1.5 turns out ..car runs much better might have too drop jets down a few sizes ,but still too rich at idle but much better than it was ...should i get some air bleeds for the idle?
thanks so far for your help jim |
ITS AIR BLEED TIME FOR SURE.
1 other thing to check is, close the throttle blades on primary and secondary then gradually open them equal amounts to get the desired idle RPM.
Mark |
| All times are GMT -8. The time now is 01:28 PM. |
