-   -   700R ? (https://www.racingjunk.com/forums/showthread.php?t=17745)
chevguy65 07-05-2007 04:52 AM
700R ?
I accidently overfilled my tranny and drove it for about 30 miles.
Could the overfill damage the trans?
It seems fine, but just wanted to know the issues if any of overfilling it.
Drained it down to the proper level.
Just got in a hurry and didn't heat it up properly before I checked it.
I have a tiny leak at the speedo cable and need to replace the o-ring in it.
TIA
bjuice 07-06-2007 05:43 PM
Most of the time it will blow it out of the vent tube ..i do not think you hurt anything..
i have done this myself before with NO collateral damage.
bJUICE
lookingaround 07-06-2007 07:06 PM
i think the most it will do is blow the front or rear seal. im sure there is someone that will correct me if im wrong. :D
chevguy65 07-06-2007 09:08 PM
No thats just ice cream :shock: :P :P :P
Seriously, thanks guys... :wink:
mountie 07-16-2007 08:38 PM
Re: 700R ?
TIA
A 700R either runs fine, or it's screwed up. If it runs fine, your tranny is fine. Make sure the throttle valve cable adjustment is correct. That's the #1 killer of 'em, after heat.
