-   -   High Idle please help (https://www.racingjunk.com/forums/showthread.php?t=17799)
rslscobra 07-11-2007 05:52 PM
Hello, :(
I installed a Holly 670cfm Avenger with vacuum 2nd and elec. choke on my 350hp. Ford 302. Cam spec. 212 / 220 - 112 - 498 / 512. C4 trans with B&M Holeshot converter and 3.73 gear.
The car will not idel properly. The idle has to be set at 1400rpm while in park. Then when put in gear it almost stalls, then idles at 800 / 900rpm. I checked for vacuum leaks by spraying crab cleaner around the intake and carb base and was unable to find a leak. Ignition is msd billet distributor and 6al box. Base timing at idle is 10 degrees, with the machanical advance adding and addition 28 degrees by 2400rpms.
rslscobra 07-13-2007 08:44 AM
FIXED.....
etbird 07-13-2007 04:05 PM
What did you do to fix it?
alscoupe 07-13-2007 04:10 PM
Yeah man, like etbird said, don't leave us hanging.
Other guys maybe got a similar problem, share the wealth, brotherman.
chevguy65 07-13-2007 04:17 PM
Originally Posted by rslscobra
FIXED.....
Whaddya do swap carbs or get a chevy?
