fuel press
what kind of fuel press semes low ? i have bg 280 pump and with truck runing i set my pressure at 8psi and i slowly drops to 6psi is that good or bad? what could do to fix the prolbem?
Are all your fittings tight but not over tight?
Where is your pump mounted? What type pressure guage do you use, I have heard that most all of them fluctuate some. Also, I am not sure but it may be normal for pressure to drop as temps come up. |
i think so?
pump is mounted in back of bed right next to the fuel cell it a jeg gauge |
my fuel is set at 6.5 and stays right abought 6.5, holley blue pump, holley regulator
| All times are GMT -8. The time now is 05:06 AM. |
