SBC 383 advise
I am building a pro street 70 Z28 and using a 383 that was built for another car with an automatic. I am using a 4 speed. So, since the engine was balanced, will I need to get the fly wheel 0 balanced? Also, any comments on RHS Aluminum Heads. Good..Bad???
383
It depends if the Assembly is balanced,Internally or Externally?
RHS Heads,VERY Good in My Oppinion? Later G 8) |
383
If the engine had an external balanced flexplate you should need the same with the flywheel .take the flexplate to a reputable engine shop (hopefully the one that originally balanced your motor) and have the two matched up. :wink:
Thanks for the reply....Anyone else have experience with aluminum RHS heads??
| All times are GMT -8. The time now is 10:27 PM. |
