Power steering question.
I took off the power steering pump from my car, a 74 Camaro and it still turns pretty easy, it is fairly light in the front.
My questions is, will this cause the steering to fail or break something? I still use the power steering column. We only use it to drag race. |
It won't break or anything outside of normal wear. You can either loop the lines in the box or cap them, as long as their is fluid in it.
| All times are GMT -8. The time now is 12:59 AM. |
