-   -   bracket race cam specs for 350 chevy? (https://www.racingjunk.com/forums/showthread.php?t=17878)
mikes 07-20-2007 05:40 PM
Hi, I happen to have this sbc combo and need your input on cams, 4.060 bore, 3.48 stroke, 12.7:1 to 13.05:1 compression depending on my head gasket, 4340 bottom w/ spr pistons...edelbrock vic jr intake. For heads I have ported canfield heads by mike stark of cfm performance...they started life as 200cc runners and ended up around 212...the flow numbers will be listed below. Id like a solid roller for a 2900ish lb car possibly a tad less, that weight is with driver. This engine will not see any street time, only a 1/4 mile bracket engine. Trans is a th400, I have no rear gear, converter or tire size yet as Im uncertain of what we're going to do rear suspension wise...either back half it or keep it a mini tub with a 28 ish tall slick. rpm is not a concern...I will gear and converter acordingly to match cam as well as have pro systems build a carb. Whats your reccomdation for specs ? Thanks for your help!! oh the ex numbers are without a pipe.
IN / EX
100 - 76 / 61
200 - 144 / 95
300 - 203 / 132
400 - 250 / 156
500 - 280 / 178
600 - 300 / 194
700 - 306 / 202
800 - 312 / 210
