-   -   How about Caltrac VS Ladder Bar ( leaf spring cars only) (https://www.racingjunk.com/forums/showthread.php?t=17968)
ericsz 07-30-2007 10:04 AM
What do you think about this one?? Do you prefer ladder bar or Caltrac on your leaf spring rig??
SST4530 08-08-2007 05:11 PM
I think if you use housing floaters go with ladder bar. If not the Cal trac works really well.
mcracecars 08-09-2007 02:09 PM
Leaf spring on a budget.... caltracs or similar....
I feel ladder bars can give a little better adjustability, but I would ditch the leaf springs and use coilovers.... if you got the coin...
but dont dismiss the caltracs, lots of cars working good with them.
edvancedengines 08-09-2007 03:50 PM
I didn't answer previously becuase I wanted to see what someone else would say to this.
My opinion is that they both can be set-up to work pretty good. They both will require some tweeking and tuning to work best. Setting pre-laod with CalTracs can get a little tricky. If you buy ladder bars do not buy the cheapest. At least get the adjustable bars so you can set pinion angle.
I will give a huge edge to the CalTrac if it is street driven. It will make a little noise but that is the only negative.
In my opinion if you are stuck with leaf springs do the mono=leafs only. Mulit-leafs are too stiff for a drag car no matter wht you read in magazines.
Ed
acpat 08-14-2007 09:28 PM
Ladder bars wear more on a street car and are real noisy. I would use a slide a link or caltrac before a ladder bar. I saw a post where it was talking about ladder bars binding when you entered or exited a parking lot.
