New Combo
I put a 468bbc in my dragster and wanted to share what it did.
stock 454 2 bolt block GM steel crank Eagle H beams Rods Ross 13:1 pistons Dart 355 fully cnc'd heads Weiand 4500 intake with minor work APD 1150 Alky Carb 196 jets 2 1/4 to 2 3/8 with 4" collector headers Star Vac. Pump 8" BTE Conv I had laying around from a 355sbc I used to run. 5800 stall It ran 5.26@130 & 8.29@160 DA was 3600ft temp was 92 degrees This car weighed 2011 with aftermark Dart block not sure what it weighs now. I have a few bugs to work out, had a set of old gas short reach plugs laying around I put in it and I am going to lean up the carb. I broke my bigger motor and got a good deal on the short block is why the big heads and carb. I've never seen anyone put this big of head or carb on this small of a motor so I thought I'd share what it did. |
you got close to what i have in the 67 Camaro..except mine is.125 over (511 ci) with a callies stealth crank 4.25 stroke
and eagle rods. braswell 1050 dominater. l love the way mine runs...3,000lb car on foot brake was a 6.07 at 115 mph..now have newer tires and a trans break..hope to go low 5.90's..all on motor.. Brian |
Re: New Combo
DA was 3600ft temp was 92 degrees I've never seen anyone put this big of head or carb on this small of a motor so I thought I'd share what it did. |
Made a few more changes took off 2" carb spacer and changed fuel pressure 5.19@130 this weekend 1/8th mile. Really bad air still cant wait to see decent air and a good track.
Put a new intake on the motor team g to 454r out of box went best of 5.18/8.27 before now it runs 5.08/8.05
Hey David, What is your egt saying?
Couldnt bring myself to drill the chrome headers I am sure its on the low side with the big carb. you have a pm also
| All times are GMT -8. The time now is 06:58 AM. |
