-   -   weight ratio (https://www.racingjunk.com/forums/showthread.php?t=18066)
twistacain 08-11-2007 06:56 PM
weight ratio
Anyone know what a good percentage to start with a a altered? Is there anywhere I can find information on tunning the chassis ona solid suspension car? Right now I have 60% on the rear 1050 lbs and 700 lbs on the front.
BillyShope 08-13-2007 04:03 AM
The percentage of static weight on the rear wheels should be no more than:
(L-2.5H)/L
where "L" is the wheelbase and "H" is the center of gravity height. The "2.5" is the coefficient of friction for a good set of slicks. The static weight bias should be determined with the driver in the car, of course. It would appear that you'll need to shift some weight to avoid unloading the rear tires with excessive wheelie bar loads.
With no suspension, it is important to build some "droop" into the left front in order to keep the rear tires equally loaded on launch (and, it should be stressed, to maintain some degree of driving safety). To determine the amount and its effectiveness, you'll need to use a traction dyno. (See Pages 4, 5, and 6 below.)
Hope this helps.
mcracecars 08-13-2007 05:41 AM
Billy, is that formula for alters only? I have a doorslammer in the shop, with the formula, it comes out to 63% max on rear tires......
BillyShope 08-13-2007 03:56 PM
Works on anything. Sounds like you have a pretty low CG and/or a pretty long wheelbase.
BillyShope 08-14-2007 03:57 AM
(L-2.5H)/L
I suppose it's as obvious to everyone as it was to Ed, but, just in case anyone's confused, the above equation must be multiplied by 100 to get a percentage. I should have said, "The FRACTION of static weight...."
