-   -   ALKY Oil,somewhere in mid MICHIGAN? (https://www.racingjunk.com/forums/showthread.php?t=18074)
bbchevy 08-13-2007 10:48 AM
Getting ready to Lite the BBC on ALKY?
Heres the Question?
I'm Located just south of Manistee,Michigan.
Where and what kind of Oil are you Guys using in your Injected Alky Motors?And,how about a Distributor?As far as someplace to buy the OIL?
If any of you Guys have a surplus of Oil,and would SELL a few cases?That would be Great!!!
THANKS
Greg
[email protected]
231 690 5075 Cell 8)
bjuice 08-13-2007 11:02 AM
You have a PM
thanks Brian
hammertime 08-13-2007 02:44 PM
valvoline 20/50 racing oil
dart441 08-14-2007 01:39 AM
Valvoline 20-50 conventional racing oil (not VR1). Jegs sells it but NAPA will sell it to you for about $1.00 to $2.00 less per quart. They don't stock it but is a cataloged item and they can have it overnight.
knova70 08-14-2007 04:43 PM
Lucas 20/50 and 1 quart of lucas oil stabilizer ,I change my oil in my Blown SBC about every 5-6 runs and I use a WIX filter,I have very good luck using this oil and filter,Hope this helps!
bbchevy 08-14-2007 06:29 PM
OIL
THANKS for your Replys!!!
I will be going with Brad Penn 20-50W and or 50w.I have found a Dealer in Dorr,Mi.
As far as a Filter,WIX are the Best by FAR!!I do have a System 1 set-up that will go on the Chassis this Winter.But,until then the Wix Filters will be in place!
THANKS AGAIN!
Greg Reed
Fountain,Michigan 8)
zipper06 08-14-2007 07:18 PM
Wix and NAPA are the same filters, Wix makes NAPA filters.
hammertime 08-14-2007 07:44 PM
and Valvoline makes napa oil ..
topsportsman1 08-14-2007 07:47 PM
I thought Ashland Oil Company made it?
dart441 08-15-2007 12:55 AM
AND: the Wix racing filter you get from NAPA don't even say NAPA nor are they in NAPA box. They are the same box/filter that is Wix everywhere else
