foot braking
I have a 3600 vert and I am footbraking, will I et better with rpms at 3000 or would it et better at 2000 and then nailing it, she will hold at 3000 rpm max. wich will give me a faster et?
Hey MARK,,,you want to leave anywhere from 700 to 1,000 below flash..this is where you will get the most performance out of your converter and the reson they are built this way..yo may have to play with it a little to find the sweet spot..a transbreak will aloow a little higher flash..
hope this helps.. brian |
Yep, when we raced No Elec. I would stall at 3000 and flash the other 1500. Really helped the 60 ft. and reaction times. :D
My old 3600 stall liked to be footbraked at 2600 for the best ET.
I could get up to about 3200 out of it if I tried but like I said it ran better at 2600. |
I know how to flash a converter with trans brake, how do you flash or know the stall of a converter in a footbrake car? Just by holding brake and gas till tires start to spin?
I leave dead against the converter with a brake...will the car 60' better with a two step 1000 rpm below the converter lockup? Car is 3050 lbs 60' is 1.32 the way I leave now.
My converter will fullout brake stall to 6000 on the trans brake with no chip. With the setup we run the car likes to leave between 4200 and 5000 depending on track conditions. Haven't been able to keep it stuck any higher than 5000 with a 10 inch slcik. 4500 hundred seems to be the best all around RPM for us at most tracks. |
| All times are GMT -8. The time now is 03:27 PM. |
