-   -   aluminum door panels (https://www.racingjunk.com/forums/showthread.php?t=18144)
ratfink1969 08-21-2007 07:23 AM
looking for supplier for aluminum door trim panels for 85 camaro, there was a guy on ebay that was selling them a while ago but I can't find him now. any suggestions.
Ryan
bjuice 08-21-2007 11:23 AM
you might have problems finding this product off the shelf..
but you have an easy problem to solve..
take the orginal door panel and trace out a pattern on the sheet metal you wish to use....if you have no door panel ..then get yourself a large piece of card board and make you a pattern..
if you want the designs in the sheet metal..all you have to do is find any sheet metal shop with a bead roller and make whatever design you want.
you can order these rollers from harbour freight for less than $100.00..
Brian
