-   -   GRAY PRIMER QUESTION (https://www.racingjunk.com/forums/showthread.php?t=18230)
alessio 08-29-2007 08:30 PM
Hello, I'm new to the forum. I have a paint question. I've seen a couple of cars that had a primer looking base, with a lime green and black coat worked in to it. Does anyone have an idea of what the procedure is? Or any other cool gray primer with other color schemes? Thanks ahead for your time...........Rob Alessio
a63jetfire 03-16-2008 06:58 AM
Don't know exactly what you mean. But paint shops will tint your primer to match the top coat color. Nice because deep scratches don't show as much.
And if they can tint the primer to match paint, there's no reason they can't tint it any color you wish.
Bubstr 03-18-2008 12:12 AM
Primer surfacer is usually the color it is. If you see a mix of black over spray, that is usually a guide coat for sanding.
Now sealers are a different story. Tintable sealer can be made about any color you want using a compatible paint to tint it. There are several types of primers and sealers and for some one that don't know get info from paint jobber on what is best under coat for the paint you use. There is a lot of difference between each kind. Some are self etching and need no etching primer some primer surfacers need etching primer under them and sealer over them. Some epoxy primer/sealers do it all in one step. From bare metal to prime to sand then paint. DDL K200 is good for this especially on a striped car. Especially for some one that doesn't do it all the time. and is going to stretch the paint prep out past a day or so. If you don't need to block a majority of car DDL DP epoxy sealers are good. They need no etching primer or sanding between sealer and color coats, but there is a time limit from sealing and painting. The bare metal needs to be finished down to a 240 DA sanding though. A big labor saver.
Racefab57 03-18-2008 04:19 PM
I just heard of a paint co. that makes the suade look I think your interested in, but I cant think of the name. I heard of this on" trucks " the show on sat, and sundays. You should be able to get the name from them,or call around. That Kevin Tetz is quite a painter in the autobody field! He's also done video's on car painting!
