Hoosier QTP 29x11.5
Do these tires need tubes in them?Also what kind of air pressure would be a good starting point in a all stock suspension nova with slide a links and a small block?.Thanks for any help.
I run Hoosier Quick Time Pro tires and do not use tubes, never have.
I have ran as much as 13 Lbs and as low as 6.5Lbs..I'd start around 10.5 Lbs and go from there. Got to check them after they cool down not right after a pass because they will vary when heated up..I think they go up about a pound from cold to hot. |
I use these also 29x14.5 I run tubes and they are screwed down. jody is a lot faster and doesnt so it looks like both ways will work. I also run 10lbs and like these slicks alot
| All times are GMT -8. The time now is 07:50 PM. |
