1 piece rear main ?
i've got a sbc w/ 1 piece rear main . i've got a leak. not sure if it's seal or pan. can i remove the flex plate and run the engine to see what is leaking?
Re: 1 piece rear main ?
But you can change the seal if you remove the flex plate :P |
| All times are GMT -8. The time now is 12:01 PM. |
