-   -   flow numbers (https://www.racingjunk.com/forums/showthread.php?t=18290)
ratfink1969 09-04-2007 08:03 PM
flow numbers
just wondering if anybody had flow numbers for the big chevy 781 heads, stock or modified.
Ryan
edvancedengines 09-05-2007 01:16 AM
I have flow test numbers for I am thinking it was the 049 heead which is the same in all respects.
It is a comparrison test of the Oval Port 049 vs the high performance square port with each head having same valves and same minor port work.
Ed
http://i22.photobucket.com/albums/b3...s/83d8a224.jpg
http://i22.photobucket.com/albums/b3...s/3c5e3ccd.jpg
[/quote]
ratfink1969 09-05-2007 03:54 AM
thanks
edvancedengines 09-05-2007 10:44 AM
I am sorry those pics came out so small. If you can't get themk to blow up bigger, email me, and I will see if I can find and send a bigger copy.
Ed
firestone 09-05-2007 03:15 PM
Here is a site with a bunch of flow numbers. There are nubers (stock and ported with larger valves) for 049 heads which are pretty much the exact same thing as the 781's
http://users.erols.com/srweiss/tablehdc.htm#BBChevy
Adam[/img]
