-   -   plug gap (https://www.racingjunk.com/forums/showthread.php?t=18392)
hotrod1024 09-16-2007 06:14 PM
plug gap
Only had my coupe about 3 weeks now andd was finally able to really drive it.Breaks up quite a bit.Has msd 6al and msd blaster 2 coil.Pulled plugs to check them.Checked gap and it is only .025.From what I have had in past with msd was told plug gap should be somewhere .050-.060.Could wrong gap have caused my plugs to foul or somehow affect my breaking up.Has autolite 45 plugs and is a 351w if that helps any.Thanks,Randy.
Racefab57 09-17-2007 07:02 AM
open that gap up,if plugs look ok. if really fouled, get new ones,gap to specs. David.
hotrod1024 09-17-2007 09:09 AM
Thanks. Gonna do that today.With gap to small could this be causing my breaking up.
hammertime 09-17-2007 09:56 AM
It sure would
hotrod1024 09-23-2007 07:31 AM
Replaced plugs and gapped at .055.Runs alot better.But now when i floor it it shuts off.Seems like its running out of gas.I can let out on clutch since its already in gear and it will start right back up.Fuel pressure is at 7 psi when shuts off.Carb is edelbrock 600.I have been told it is too small and am planning on replacing with Holley 750 dp soon.Could carb be primary problem.Thanks for advice on plugs.
cepx111 10-03-2007 10:25 PM
Oh the dreaded edlebrock peformer flat spot, junk that carb and save yourself the headache of even thinking you can get it right.
I would recomend a Holley HP 650 double pumper unless your motor has allot of compression and cam your gonna want the smaller carb.
You'll get much better throttle response from a smaller carb than going to a bigger one like the 750. Also I would recomend a tad less plug gap than .055, somewhere between .035 and .040 is where you wanna be.
Goodluck, Charles
hotrod1024 10-04-2007 02:16 PM
Thanks Charles.I did gap at 45 and runs alot better.Carb was gonna get replaced,but I traded car this week for a 68 Firebird prostreet project.Thanks to all replies Ive gotten on this and other subjects.Im sure I will need more advice on new project.Thanks again.http://i200.photobucket.com/albums/a...gt005Small.jpghttp://i200.photobucket.com/albums/a...gt009Small.jpg
cepx111 10-09-2007 03:06 AM
No problem, were more than happy to help.
hey is that the BIRD in the avatar?
Charles
hotrod1024 10-09-2007 05:53 PM
Yes Charles it is a 68 firebird i just got on Sunday.Been trying to get for 15 years from long time friend.Finally worked out deal on it.He doesnt have time to work on it.Lost interest.Hasnt been touched for 5 years till sunday.Stored in garage.
woodsman 10-09-2007 06:49 PM
If anyone wants to run a larger plug gap than they are running now check out this site on mini VIP. http://www.performancedistributors.com/
