Header and brodix T1 heads
The headers i have dont seem to have the "D" shape ports that the brodix heads have. Do they have to have the same shape? The holes are in the right place, just not the same shape? If they have to be the same, whats a good header that will fit the Brodix track 1 heads?
I run 1 7/8 Hookers with track-1 heads, they come with adapters to the chev pattern at a cost of about $500.00.
Zip. |
I'm running a weld up kit header with 2-1/8 round tubes with my Track 1's. The tube is big enough that there is no mismatch.
curtis |
No adapters, the headers were on it when I got the truck. In fact, the engine that was in it had Track 1's on it. The tubes are formed at the header flange and are not perfectly round, kinda flat on the header bolt sides. And yes, they are 2-1/8 'cause I had to replace the collectors (bolt on) 2 years ago after a race at a junk local track ripped them off.
Curtis |
So will rectangular headers work on a head with "D" ports?
Zip. |
| All times are GMT -8. The time now is 04:48 AM. |
