-   -   homemade launch pad/ glue (https://www.racingjunk.com/forums/showthread.php?t=18465)
slagburn 09-24-2007 07:42 PM
Say, in theory, there's a good sized chunk of asphalt (not concrete) nearby that a guy would like to give some traction, and there won't be a ton of traffic messing with any prep work.
Is it as easy as purchasing some vht track bite and a weed sprayer? I've heard mention that pouring root beer around works too.. :D
How far does a gallon jug of trackbite go, and does it need diluted?
Thanks for any help.
jaykz1000 09-26-2007 03:32 PM
all u need is some VHT .. on the vht less is more method works best ..if u get to much on the ground and cant burn it off then its just like water.. best if u have a car u can do burnouts with as well..pour u a small puddle out in front of the back tires and do a burn out threw it then back up and do one right next to it overlap just a lil then do a nother on the other side.. makes a nice rubber launch pad..if your not going to race right that second then go over your marks with a sprayer if u want and light on fire or let dry .. u can also light the VHT on fire if u have to much and cant burn it in the ground... if u plan on racing right then and there i just do the puddle and burnouts then race right after.. not that ive ever done anything of the like ...lol pm me if u need any more info u can also use rosin aka gold dust
jaykz1000 09-26-2007 03:34 PM
if u put in sprayer dilute with alchol.. make sure u have some rubber gloves also ... itll get all over ya...
Tod74 09-27-2007 06:33 AM
ROOFING TAR.
:lol: jk
excelerater 09-27-2007 12:28 PM
VHT is not the cure all for track prep and most times
it does more harm than good -
buy some velcro :P
Tod74 09-29-2007 04:52 PM
:P
How so?
