carbs to suit sbf
Hi just wondering if anyone could tell if a set of Carbsmith ProStock Truck 358ci Carbs would work on my SBF. Here are the specs.
388ci sbf Specs on SBF 4.155 bore 3.585 stroke, yates heads 373/274cfm, 2.150/1.600 valve 278/300 @ 050/ 115 lobe sep 16.1 comp engine turns 9000rpm and made 825 hp with cast intake and single dominator. Looking to make 860hp with sheet intake. Pipes are 1.7/8-2.0-2.1/8 - 3.5 collector pipes |
| All times are GMT -8. The time now is 07:43 PM. |
