-   -   Brad Penn or VR1 (https://www.racingjunk.com/forums/showthread.php?t=18497)
et7333 09-29-2007 07:56 AM
Brad Penn or VR1
which oil would you use in your flat tappet motor:Brad Penn 10-30 semi or 10-30 VR1{VV205} or valvoline conventional,not for street use,{VV850} 10-30 and why?I've noticed the ZDDP is Lower on the BP then the Valvoline
hink 09-29-2007 08:16 AM
We use the Brad-Penn 20/50 for cam break in only as its sold as a racing oil and the 10/30 oil I believe is not a racing oil Correct?
bubbabbc 09-29-2007 08:44 AM
oil
You are right on the money, Hink. Brad Penn oil is highly recommended by most camshaft manufacturers.
et7333 09-29-2007 09:02 AM
I will be using the 30 wt breakin BP oil,but was just curious, for regular racing use, which of the two oils would you use?
superpro1832 11-29-2007 04:55 PM
b/p oil
I have used the brad penn 20/50 in my alky engines and also vr1 20/50. Seems to me that the b/p oil does not break down as fast as vr1. bearing life has been extended since using b/p oil. I am running the same r/m bearing 3 seasons drag racing on 1/8 mile.
jmarksdragster 11-29-2007 05:37 PM
Just a note, Joe Gibbs has a new oil. A bit pricey but has more zinc. He also has a break-in oil.
