comp cams belt drive
anyone out there running a comp cams belt drive on a big block chevy with ati balancer ,did you run into any problems.how do you think it compares to a jesel?
Cam belt drive systems
We have been running a comp belt drive for 6 years on our bbc. Never had any problem. So I have never used a Jesel system. But I have never heard anything bad about them. You would not have any problems with either one you choose to use.
gyrogearloose |
was there any interference problems with balancer,i run an ati balancer?i put one on a 400 small block i had and than the balancer did not fit.
belt drive
We use an ATI balancer also. No problems.
gyrogearloose |
THANKS FOR THE INFO.
| All times are GMT -8. The time now is 03:18 PM. |
