-   -   Taller engine fit in a 68 Camaro SS stock hood? (https://www.racingjunk.com/forums/showthread.php?t=18714)
r8ceredy 10-23-2007 08:09 PM
Restoring my 1968 Camaro SS back to a BBC. Curious if anyone has a BBC with a taller deck block or a stock deck block with a taller aftermarket intake like a Edelbrock Victor or Super Victor while retaining the factory SS hood. Very hard to find info out there as to clearances under the hood and I hate to pony up the money to get a new intake and get it port matched only to find out I can't close the hood :cry:
Let me know what you got
Thanks
mcracecars 10-23-2007 09:19 PM
I would doubt it if you use such a tall intake witha dominator, then an airfilter.... I would doubt it on a standard deck as well....
best to do some carefu measureing... or if you are in good with the local speed shop guy, order the intake you want, and with the motor in the car, set the new intake on top and see if it all will fit. If not return the intake.
r8ceredy 11-16-2007 08:05 PM
I suppose that old "measuring" thing probably would work better than the "buy and pray" method eh? :oops: :oops: :oops: :oops:
lively 11-17-2007 05:53 AM
YOU COULD JUST PUT IT IN AND KEEP SLAMMING THE HOOD DOWN TILL IT LATCHES :oops: :oops: :oops: ---ONLY KIDDING!!!!--LIVELY
kw89425 12-25-2007 02:11 PM
i have a 68 with standard block and not a real tall intake i have a 4" hood and i can look up through the fenderwell and see almost all of the breather is up inside the hood with a 2" hood you have to use a very thin breather.
insane4fbodys 12-26-2007 07:14 AM
Unless your going to build a all out race motor. Use a standard deck and if you have rectangular heads, get a factory HiPo aluminum intake. They made good power and fit under the factory hood with 3" drop base filter with a holley carb. Just a thought.
strokercamaro 01-01-2008 06:25 AM
I had to use a stock style gm intake and a factory drop base air cleaner to ge it in there. I had the stud to long and put a dimple in my ss hood, so I went to a factory cowl hood.
Greg
