THREADED TUBE INSERTS
Can someone tell me where a reasonable place is to get the threaded inserts that you put into the end of tubing and weld it up so you can use rod ends.Thanks
www.chassisshop.com
they got em in all sorts of sizes....left, rights, hex style..... |
Any racecar chassis supply shop. They are usuallu called Weld Bungs. They are made with right hand and with left hand threads.
If installed in 4130 chromolly tubing they need to be Tig or heli-arc welded. Two different terminology words. Ed |
| All times are GMT -8. The time now is 03:41 PM. |
