-   -   BBC HEADS ALUMINUM OR IRON (https://www.racingjunk.com/forums/showthread.php?t=18754)
dizney4 10-29-2007 05:12 AM
Going to build a 396 for a 69 Camaro. This will be a street car that will see the 1/4 mile maybe a couple of times a year. My goal is to get around 500HP. My question is should I put on aluminum or iron heads? And why? Thanks for your help.
Tod74 10-29-2007 05:43 AM
Aluminum..With a big block chevy you will take 75 lbs off the car by going to aluminum heads.I also think you can get away with a little more compression with the aluminum vs iron. (pump gas)..not possitive about the compression but I have weighed BBC heads both iron and aluminum and the difference was 75 lbs on mine...
