setting total timing
Let's say TDC on my motor is at the 5 degree mark on my balancer. I want my motor running at 35 degrees total. Would I add 35 degrees to my 5 degree TDC mark and set it at the 40 degree mark on balancer?
-Tanner |
Yep. That'll work. Also Mr. Gasket makes an adjustable pointer where you can set the pointer to point at 0 instead of 5. Makes it less confusing but the way you're asking will work fine too.
George |
Thanks, just one of those little but important things you wanna make sure your thinking in the right direction about.
Let's say TDC on my motor is at the 5 degree mark on my balancer Ed |
I was just throwing that number out there for easy math.
Here ya go..... http://www.competitionproducts.com/p...s.asp?dept=616
I had one (a bit used) in an engine I traded for so I just bought two more for the two I'm building right now. Fully adjustable, but make sure you don't stab yourself as I did with the tip, it's sharp! |
I set my timing by revving the motor to 3000RPM and put in the timing I want on my light and I move the distributer until it reaches "0" and then I shut it down and tighten down the distributer then a quick recheck to see if it is still there..Is this the same principle?..
Thats exactly the method I use, verifying that the pointer is aligned with TDC first.
Cp |
Not sure mine is a Digital Acutron Timing light..I have never been told not to use it..
| All times are GMT -8. The time now is 07:26 AM. |
