-   -   car bogs leaving line (https://www.racingjunk.com/forums/showthread.php?t=18797)
alleyk 11-03-2007 12:10 PM
what could cause this problem
rabiddawg 11-03-2007 02:04 PM
does it bog then catch up?
if so it can be your pump shot.
But without knowing what carb you have its gonna be difficult to diagnose.
also engine specs help too.
alleyk 11-03-2007 03:03 PM
yes it doe's pick up afterwards, the carb is a davinci 750,
engine sm blk 414,with 638 roller cam,brodix heads
superstreeter 11-03-2007 03:09 PM
I imagine, you are running jet extensions in the back, right?
alleyk 11-03-2007 03:18 PM
yes i am,with 88 jets
superstreeter 11-03-2007 03:20 PM
What kind of r.gear, compression, and stall ?
alleyk 11-03-2007 03:33 PM
538 gears,12to1 comp,6000 stall.
superstreeter 11-03-2007 05:37 PM
sounds like pump shot, you got lots of everything else! I kind a have a question to add to this, would a power valve in the back cause this same thing ? or would the jet extensions take care of that,,,I`m not exactly sure where the power valve draws its fuel from.I don`t run one so I have never chased that problem.
Tod74 11-03-2007 06:00 PM
aRE YOU FOOT BRAKING? Cause If you run a trans brake it wouldn't be the pump shot since the throttle is already wide open.
cepx111 11-04-2007 06:52 PM
Good point Tod.
Alleyk, we definetly need to know if your footbraking or leaving off a transbrake to help diagnos this problem better.
To answer superstreets question, the power vavle is supplied fuel from the bowls themselves and yes it can be a problem cars that leave real hard since the fuel in the rear (secoundaries) bowls is trying to climb up the back of the fuel bowls away from the jets and power vavle intake. I've always plugged them anyway to eliminate that possiblity and went up a few jet sizes maybe 4 at the most, not ten like everybody says.
Cp
