rear disc brakes
:?: does anyone know of an economy set up for rear disc brakes on a 9" Ford rear end? I have a `66 Bronco axle that I want to put in my `47 Ford Coupe. I don't have any brakes now. The Bronco has a 5x51/2 bolt circle,
any help would be appreciated. thanks! |
Strange has a cheap disc setup Ive used on strip/street cars. its actually uses bronco rear disc's, has an emergency brake setup, and is reasonable, try em.David.
re
thanks for the info. I will look into that set up.
Also check checkeredracing.com they have a setup for stock axles. also check speedwaymotors.com they have a setup that uses stock gm calipers. also designed for stock axles
thanks for the help. I will be checking these out.
| All times are GMT -8. The time now is 06:45 PM. |
