-   -   64 impala ss vin number (https://www.racingjunk.com/forums/showthread.php?t=18842)
RSM 11-08-2007 05:26 PM
how can i tell if vin says car is a SS
dragharley1 11-08-2007 05:49 PM
the second and third vin number would be 14
bjuice 11-09-2007 04:35 AM
hey dragharley1...do you drag a harley ?
i got some buddies really heavy into this down here..got one buddy that has a stock 80ci 1992 lowrider full street trim,stock back tire. rides the bike to the strip and has run a 6.70et at 105 mph...the only after market item he has is an air shifter that he has wired thru the horn button.
not to bad for a stocker day crusier huh ?
Brian
chevguy65 11-09-2007 04:47 AM
This will give you what you need...but the 1st 3 digits should be 413, or 414
http://www.yearone.com/updatedsingle...szvinplts.html
dragharley1 11-09-2007 12:46 PM
i used to drag one , had my streetbike going 11.20 spinning and had a kosman running in the low nines ,with a destroked sporty motor,still have the motor but maybe someday will get back in it , the car bug has caught me again so hopefully will be racing that tis upcoming season ..
bjuice 11-09-2007 01:11 PM
wow !!both of those bikes was nothing to sneeze at...the Kosman was stroking for sure....later and good luck with the cars.
Brian
