anyone got a desktop dyno?
someone plz run a virtual dyno on my setup
406 cu inch smallblock 12:1 compression titanium rods 6800 rpm (should go more but this is a safe RPM) cam specs: 290 intake/290 exhaust adv duration @.050 222intake/222 exhaust valve lift .477 intake/.477 exhaust lobe c/l 114 1:6 roller rockers stud girdle brodix spec heads part number (SPCH) head specs: 215 cc intake ports 2.080 intake valves 1.60 exhaust valves super victor intake (single plane) 3600 pound car 190 pound driver 3:73 rear gear ratio TH 350 3000 stall converter 27.0 inch tall tires 12 inch wide |
I ran that same cam in a 10:1 406 SBC and it flat hauled, have fun.
I have to ask, why are you going to run titanium rods in a motor you are looking to run a "safe" rpm? Also if you want someone to run a drag program you need to include tranny choice.
Curtis |
opps ok I fixed it
car has a TH350 the engine came with the rods so ill use em. I figured 65000-6800 would be a good starting point because all I know about the motor is that its a modified IMOD motor. still has the original cam which they are restricted to use . its good to hear someone else ran that cam in a 406 I was kinda concered that it was pretty small. |
Man the rods are worth more than the engine, wanna trade them for some good H beams. Hehe JK :lol:
Zip. |
yeah even though the effective range of the cam is below what the rest of the rotating assy can handle I was gonna use it anyhow for the street.
that why I wanted to see what the motor will put out. |
Just my opinion here mate... over here we'd never put a cam which is as small as the one you've listed into a motor of that size, even for full street use. I'd be heading towards 0.550" lift at least with a 112 l/c minimum (probably a 110 l/c) & 246 @ .050". That is a baby cam which will idle real smoothe.
Even my road car which has a baby 310ci V8 in it has 0.555" at the valve with 1.65 rollers, 108 l/c & 248 @ .050". The cam just seems way too small to me. :) |
yeah I know its being changed now but I wanted to see the numbers once I found out what cam is in there.
I got an ISKY roller cam and durathon roller lifters on the way Brand: Isky Racing Cams Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 3,000-7,000 Intake Duration at 050 inch Lift: 238 Exhaust Duration at 050 inch Lift: 248 Duration at 050 inch Lift: 238 int./248 exh. Advertised Intake Duration: 284 Advertised Exhaust Duration: 294 Advertised Duration: 284 int./294 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.608 in. Valve Lift with Factory Rocker Arm Ratio: 0.578 int./0.608 exh. lift Lobe Separation (degrees): 110 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Grind Number: RR-284/294 that should wake up that motor. |
| All times are GMT -8. The time now is 08:44 AM. |
