O-RING ON CYL HEADS
I AM BUYING SOME HEADS THAT ARE O-RINGED, WILL THIS BE A PROBLEM ON A BLOCK THAT IS NOT O-RINGED OR DOES THE BLOCK NEED TO BE O-RINGED ALSO TO MATCH. CAN THE O-RING BE WELDED UP ON HEAD THEN MACHINED DOWN.
Are the heads aluminium?? :?:
| All times are GMT -8. The time now is 12:01 PM. |
