rotor phaseing
i believe msd says to use a non adjustable timing gun to do this. i set my crank trigger with a adjustable gun with the knob turned to o, so wont that work also for the phasing? thanks guys
I use the same gun with a adjustable knob and it works fine using it to phase the distirbutor,just make sure it's on 0, Hope this helps?
make sure you get it right for your application......
I goofed and it cost me about 1000.00 in repairs plus down time |
it checked out fine and need no adjustment, thanks for your reply as i did use my gun zero'd out
| All times are GMT -8. The time now is 08:26 AM. |
