7al3
Thinking of switching my 7al2 and retard box out for a 7al3 box with all the built in stuff (lack of room in car). I know the 7al3's used to have a lot of problems, any of you guys using them if so any troubles ?
thanks |
Im running one ,had one in camaro have one for vette, only thing i had for a problem was when i used the rpm activated switch to work the electric shifter it would shift it at 1/2 the rpm dialed into the box. so i use a seperate rpm act switch. great box, also with that problem it may have been something i did wrong!!!! David.
Not worth spending the money for. The Digital 6 is a better choice and has as much output as a 7AL. Digital 7 is even better.
digital 7 is just to darn much $$ after I buy everything for it. |
You would need the Digital 7 for the third step. What other parts would you need to buy? Coil? The advantage of being able to plot a timing curve, large start retard, and even individual cylinder timing make it worthwhile. I have one on my new dragster and I love it. You can even change the timing for each gear change.
A programmer correct ?
Any PC with a serial port will program it. I have a used laptop that does the trick.
| All times are GMT -8. The time now is 06:38 AM. |
