-   -   622CI ROTATOR (https://www.racingjunk.com/forums/showthread.php?t=18888)
FAT622 11-14-2007 01:43 AM
622CI ROTATOR
G'day,
can any body help me with pricing on a BBC rotator?
4.75" crank
4.560" bore
6.7" rods
comp between 11 and 13 to 1
for street and strip
6500/7000rpm
1000hp
dart big m 119cc heads
merlin 111 block
has to be shiped to Albury Australia 2640, i have contacts with shipping containers.
rob
hammertime 11-14-2007 12:54 PM
are you wanting to know what parts to put in it ? or wanting to know prices of certain parts for it ?
FAT622 11-14-2007 01:36 PM
after combinations and pricing, i have found some deals but im not getting good feed back :roll:
just after a reliable source and good deal, our dollar is heading for 1:1 with yours :D , a good time to buy.
lmchevy 11-14-2007 02:45 PM
ohio crank
Check with Ohio Crankshaft i've had good luck with their shortblocks.Their rods and cranks are forged the same place eagle is.ohiocrank.com
FAT622 11-20-2007 10:47 AM
can anybody else help me? :roll:
edvancedengines 11-20-2007 11:15 AM
I apologize to you.
I will get back to you.
After I saw that recommendation for the Ohio Crank junk, that did it for me. That is the last company I would ever consider talking to again. They do have a few satisfied customers though.
https://speedtalk.com/forum/viewtopi...ght=ohio+crank
Ed
FAT622 11-20-2007 02:11 PM
thats why i am still looking :wink:
lmchevy 11-20-2007 03:14 PM
crank
If you are getting bad feedback on everything else then buy all Callies stuff and be done with it.
hammertime 11-20-2007 04:33 PM
Buy callies compstar stuff its not bad
Certains builders wont use nothing but eagle some wont use eagle some wont use callies, some wont use oliver, some will use ohio and love it other swear at it. Everything breaks once in awhile it does happen.
I know a lot of eagle stuff is out there and not a lot breaks, ohio is a lot better then they used to be.
lmchevy 11-20-2007 05:03 PM
crank
I second that Hammertime.I have run an Ohio Crank rotating assembly for three years with no problem.If you listen to what everyone says about something you will almost always hear of a bad deal,and if you listen to everyones bad deals you will eventually run out of products to buy.If something is half price of a big name product then automatic people think it is junk.Maybe that is right and maybe it is not.I wonder what people would think if Eagle or any of the cheaper companies raised their prices higher.Would it be better.Bottom line is if you can't afford the big name stuff then you are going to have to make a choice on which one to buy.
