front coilover Q
where is a good place to buy a front coilover setup for a vega??? thanks!!!!
i run the QA1 on the front,,they bought out carrera... and strange on rear with hyper coil springs....
so far i have not got a clean 60 ft just yet..but i did post a 1.32 60 ft with a wheel stand and peddling car...car is 3100 lbs...if this tells you something about the springs and shocks i run.. whichever you choose to go with be sure you get the bearings and races that go at the bottom and/or top of shock/spring that will make it much easier for you to adjust with spanner wrench. good luck brian http://www.carrerashocks.com/qa1_ind...absorbers.html |
thanks, for the reply! i am looking for the tubular a arms and all. i wonder if anyone sells a whole kit for the vega?
| All times are GMT -8. The time now is 02:55 AM. |
