seats for aluminum heads
this is my first set of aluminum heads that i am putting together,
do the aluminum heads require cups for the springs so they don't damage the heads? i am using a mechanical roller cam and springs with a lift of .635 and 1.55 dia. spring w/damp seat pre: 135 @ 1.880 and open pre: 350 @ 1.250 coil bind @ 1.150 the heads were new but out of a box and had no specs. thanx :) |
you deffinately need hardened spring cups or washers or the spring will cut into the head
thanx bud, ordering the valves and all components that i might
need to get these heads, i will ask if the valves should be longer with the seat added :? |
| All times are GMT -8. The time now is 01:58 PM. |
