piston ring gap
I have tried doing a search on the net and cannot find any info on what i should gap my mahle psitons rings for a sbc 383....they have metric rings 1.5 mm 1.5 mm and 3.0 mm rings part number sbc125030d11......my 383 sbc with 65 cc heads make 13.42 cr.........i am googled out looking thanks guys
Whatever the manufactuer recomends, there should be directions with them, should be determined by bore size.
When all else fails, read instructions. :D :D |
What application, any N20, aluminum or iron block,filled or not? Bill
When all else fails, read instructions. :D :D I am not using nos and the block is iron and the block is not filled......strictly drag application.........thanks |
We use .005 per inch of bore and .002 larger gap on the second ring than whatever you run on the top.any questions feel free to call me @ 828-286-0780 Bill
Re: piston ring gap
Re: piston ring gap
Originally Posted by poncholvr
not a quote here - just wanted to say thats a nice lil car you have - pinto, i think its the best one ive ever seen |
| All times are GMT -8. The time now is 09:04 AM. |
