-   -   SBC Small base roller cam question????? (https://www.racingjunk.com/forums/showthread.php?t=19146)
qwk63chevy2 12-07-2007 09:36 AM
I have a .900 base circle cam for my race motor I'm putting together and want to order some roller lifters. I was looking at cranes vertical bar and horizontal bar lifters. I was discussing it with a friend and he mentioned that the horizontal's won't work w/ the small base circle cam, if anyone truly knows please post. Thanks
jmarksdragster 12-07-2007 01:38 PM
A .900 base circle cam may need vertical bars, or may need taller lifters. I have an .850 in my 427 SB and had to go .300 tall on lifters, horizontals hit the block preventing the lifter from contacting the base circle.
sp2816 12-07-2007 02:06 PM
What block are you using? If you are using the Dart or the Bowtie block then it will be tight, because I think they both use the 0.300 longer lifters. They sell roller lifters that are even longer for the short base circle cams $$$$. (I think that it was 450.00 for CompCams vertical bar lifters)
I put an engine together with the Crane horizontal spring loaded lifters and the Dart block and the springs were compressed almost completely. It turned about 7300rpm's for two years without problems. You have to be careful about the lifter compressing completely against the link plate, but not touching the cam lobe, therefore giving you more valve lash than what the feeler gauge shows.
jmarksdragster 12-07-2007 04:07 PM
Exactly. I bought Howard +.300 from Competition Products, about $300.00 and no issues.
sp358t 01-01-2008 12:55 PM
I've used the standard crane horizontal bar lifters in a standard block with a .900bc cam with no problems
Scott
knova70 01-01-2008 04:39 PM
I use stock height roller lifters on my 436 SBC with a 875 Base circle cam,with no problems,now I am using the lifters in my aluminum block with the same cam and no problems
sterry571 01-08-2008 05:13 PM
im using a stock 400 block with a 900 base cam and have no problems with comps roller lifters.
jmarksdragster 01-08-2008 08:35 PM
I also have a .900 base circle .625 lift that works on a factory block with horizontals. It is best to check before you buy, find someone with an old pair of lifters you can test fit. No sense spending money only to find it won't work.
