-   -   TORQUE CONVERTER (https://www.racingjunk.com/forums/showthread.php?t=19166)
doorjammer 12-10-2007 02:25 PM
TORQUE CONVERTER
hi
I have a ZZ4 350/355.....stock bottom end power plus open plain intake
demon 750 carb...edelbrock rpm heads 202.160...64 com.chamber..1.5
roller rockers..hydraulic roller cam....234..242@50 ADV DUR.296/304 LIFT
LIFT 539/558.......... TRANS TH350 HUGHES...converter 3500. well
From at stop sign i put it in low...roll out about 20mpr then hit it.It blows
the tires off... shift from 1 and 2......this is on a street car...I was thinking on goin to a.....3000 to 3200 converter.....4.56 gears 29in tire.........thanks
Butch
youlose 12-11-2007 02:25 PM
your welcome
bjuice 12-11-2007 03:53 PM
just reading thru your set up motor/gear etc...i would not waste my money droping the converter from a 3500 to 3000/3200..
You have enough motor with that 4.56 gear to blow the tires off everytime..you will still blow them off with a 3,000 converter as well.
its a lot of gear for a street car that is drivable..also the nature of the hard compound street tire..and the street itself is not for hooking....
the 3.73 gear is a good street strip gear..if u do not want to cut it back that much then i would go 4.10/4.11..but no more..it its s true street car.
also if you want tighter converter you can always send yours back and have them tighten it up..i assume you have a huged converter as well ?
my wife has a 69 camaro 460 hp motor..29inch dot streets with a 12 bolt 4.56 gear and it will blow them off on the street everytime...but she runs this car at the strip..otherwise i would drop her gear to a 3.73,,,she has a tci 3500 converter and 350 turbo tranny.
Brian
poncholvr 01-19-2008 10:22 PM
if you go to a smaller converter, you will lose on your rpm's- and it will not hook up right i dont think-,also it might want to die or stall out the motor from lack of reaching the higher rpm's
