TOPLOADER INTO FOXBODY STANG
JUST WONDERING IF ANYONE HAS TRIED THIS. I'VE AREADY GOT THE BLOWPROOF BELLHOUSING, TOPLOADER, SHIFTER. THE CAR IS A 91 WITH SHORT TUBES SO THE EXHAUST SHOULDN'T BE A PROBLEM, BUT IF ANYONE HAS A SUGGESTION ON THE SPEEDOMETER CABLE & GEAR.
AT THE SAME TIME AS THE TRANNY SWAP, IT WILL BE GETTING CONVERTED TO A CARB SETUP, THAT WILL ELIMINATE THE SPEED SENSOR. IF ANYONE HAS ANY TIPS, LET ME KNOW. THANKS. |
| All times are GMT -8. The time now is 10:30 PM. |
