-   -   sbc block freeze plugs leaks (https://www.racingjunk.com/forums/showthread.php?t=19182)
et7333 12-11-2007 07:04 PM
Are there any sealers that will work on a very small leak on a freeze plug without using block sealer or removing the soft plug?
jmarksdragster 12-11-2007 07:51 PM
If you are looking for permanent fix, forget it. You can get rubber screw in for a temp fix, the best way is to replace it.
davis419b 12-11-2007 07:55 PM
What is a soft plug?
hammertime 12-11-2007 08:25 PM
I was thinking the same :lol:
davis419b 12-11-2007 08:28 PM
I ran a SBC for 12 years and never heard of a soft plug and have been through plenty of engine projects ? Got to be a freeze plug!
hammertime 12-11-2007 08:34 PM
I would think so also ... but maybe we are just outdated now :D
rabiddawg 12-12-2007 02:19 PM
yeah i seen the rubber (temporary)plugs
pretty easy to install but dont think about using those at the track!
screw in are the best.
there is a pic of one here
http://www.automedia.com/Replacing_a...cr20070401fp/1
I always learned to pin the plugs and use a bit of indian shellac sealer on them .
SST4530 12-12-2007 06:03 PM
definitley replace the plug with a brass plug and put a good coat of permatex on the backside before installation/ Just my $.02
et7333 12-15-2007 03:52 PM
Thanks for the info-I replaced the freeze plug and put Indian Head sealer on it.No more leak
dart441 12-22-2007 04:31 AM
Frost plugs are freeze plugs are soft plugs. Depends on how old you are and where you are from. Install them w/ an epoxy or JB and they wont leak. Also use brass ones and they won't ever rust through. That's important I guess if you can get a block to live a bazillion passes.
Duane
