-   -   engine gurus inside plz (https://www.racingjunk.com/forums/showthread.php?t=19191)
rabiddawg 12-13-2007 02:04 PM
this guy i know is using this as gospel?
i see alot of wrong info.
specially #7
What are your thoughs?
10 Engine Wives‘ Tales - Debunked
by Don Terrill ©2003
1.) Grinding a crank under makes it weaker – Cranks always break in the same place, the radius – it’s the weakest part of the crank. The larger the radius, the stronger the crank. When a crank is ground there’s actually an opportunity to increase the radius and thus increase the strength of the crank. It’s all in the hands of the person doing the grinding – choose him or her :) wisely.
2.) Fuel Injection always makes more power – Fuel injection does a great job when throttle position changes often. For types of racing where the throttle is wide open most of the time (i.e. drag racing), a carburetor is a formidable opponent – especially when matched against throttle body injection.
3.) Too much spring pressure is hard on valves – What’s hard on valves is the speed at which they contact the valve seat at closing. What dictates how hard the valve hits the seat? It’s supposed to be the camshaft closing ramp, but when spring pressure is too low the valve does not follow it’s intended path and instead slams into the seat and actually bounces. So, actually more spring pressure helps the valve by forcing it to more closely follow the cam shape.
4.) Rod bolts break because they’re bad – Rod bolts are falsely accused of engine failure more often than any other part in the engine. 99% of the time a rod bolt breaks it’s not the bolt's fault, it’s the engine builder's fault – more directly the one who torqued the rod bolts. Not surprisingly, I’ve had a hard time getting people to agree – it’s a lot easier to say and believe that “It’s not my fault.” Rod bolts work by stretching, usually around .006”. They’re almost always less (say .004) when torqued with just a torque wrench. A stretch gauge is the only way to go.
5.) A 10qt oil pan needs 10 qts – Your engine needs only enough oil so the oil pump pick-up never gets uncovered, not an ounce more. I think you’d be surprised how little an engine can run on – I’ve raced with three before and heard rumors of racers successfully using even less. If pan manufacturers would stop “rating” their pans this way, the confusion would eventually end. Most wet-sump engines are perfectly safe at five quarts.
6.) Head gaskets can’t be reused – Motivated by the cost of current racing head gaskets, I started reusing them. The shorter the engine run time, the better your chances of success. Buy one set of gaskets, use them when honing with torque plates, reuse them for mock up, reuse them for assembly and reuse them after tech teardown. The biggest risk is a water leak – if that portion of the gasket looks good, go for it.
7.) Glowing headers mean the engine is lean – This wives’ tale is starting to lose steam, but still believed more often than not. Headers glow red for only one reason, there’s fuel burning inside. The two main reasons are a rich mixture and late ignition timing - which doesn’t give the fuel enough time to burn inside the combustion chamber. Test it for yourself, let your engine idle and crank the ignition timing back to the point where it barely runs, then get out the marshmallows.
8.) Bigger cam and ports = more max power – I know that most people now understand that bigger is not always better, but there’s still a great many people who think that bigger always means more peak power. Well, this isn’t true either, too big a cam or ports can lead to reduced cylinder filling, which in turn leads to LESS max power. Remember, everything in moderation.
9.) Setting ignition timing by ear works – There are still some old-schoolers left that believe this one, and you can’t tell them otherwise. Someone setting ignition timing by ear will always end up setting the timing too high – at idle it sounds great at 60 BTDC, at 7000 RPM (under load) I’m sure it’s down right scary.
10.) Flick ashes in the oil pan for good luck – Now this is a real wives’ tale. Believe it or not, people actually do this – I’ve seen it. If your engine builder thinks he needs some good luck, maybe you need a new engine builder.
Think I’m out to lunch? Fine, write your own article
www.RacingSecrets.com
topsportsman1 12-13-2007 02:21 PM
I see nothing wrong with #7 its a fact,its true,what don't you agree with
rabiddawg 12-14-2007 08:27 AM
i fuel really has nothing to do with it.
it doesnt have to be overly rich to make the headers glow.
also the other post about reusing head gaskets (i disagee)
maxpower671 12-14-2007 08:49 AM
quality gaskets
re-using head gaskets can be done. i know a guy that does, sbc twin-turbo, efi, gasoline. quality gaskets, machining, assembly, no problems. this engine produced at least a thousand hp...
edvancedengines 12-14-2007 10:18 AM
Take most everything that Don wrote and take it to the bank. All true and good info. Except maybe the part about the EFI. Of course he said FI didn't he.
#7
He said too much fuel or too late of timing. Meaning timing retarded too far. He said the red glow is fuel burning in the header. All true.
Tell me what else can cause the header to turn red?
At least with copper. I re-use copper head gaskets a very long time. Be sure to match them up to the way they came off when you clean them and put them back. I have re-used a Fel Pro Blue Gasket one time in an emergency but for only one race and then I re-placed them with new. Maybe I wasted time and money.
Ed
bjuice 12-14-2007 10:38 AM
#6- i agree with that they can be re-used....
however would i re-use them :?: ...No i personally would not....but thats my opinion....maybe i am wasting money...then again maybe i am not :?:
then again i check the front air pressure as well as the REAR...i change spark plugs more than the average guy..i adjust valves after every trip to the track....i work with my car on 4 jack stands to get it free rolling as freely as possible ..front and rear wheels.
is it neccessary ?.....maybe not so much as i would like to think but you can rest assure its right and it is as good as it will ever be everytime out. 8)
and i ALWAYS,ALWAYS try 200% NOT to work on my car at the track..other than something like some timing adjustment and placing fuel in the car.
i am FAR from a pro or any track champion of any sorts in this game....
but i can assure you anyone that has some real credentials such as Championships,record holders.....you can Rest assure these are some Anal people on their race cars..all around
I hope whoever you choose to build your engines..is One Anal fart...thats when everyone luv's us Anal people.
maybe i am off on a tangit..but remember i am an Anal ole dude.
thanks Brian
